dotelvis
Jun 30, 2021Aspirant
PLEASE HELP
Why does my router update then tell me it has FAILED? Then it reads 403 error; page not available.
ROUTER MODEL: WNR2000v5
Thanks for any help you can give me; otherwise, Netgear will charge me $89.90 to help me!
- olympos1625NETGEAR Employee Retired
Hi tddougla,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching out. May we know what are the LED lights on the router( color and behavior)? Do you still see the wifi signal of the router? Please DM us the serial number of the router.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- dotelvisAspirant
My router has 3 lights, neon in color and steady with NO blinking. The Serial # is 3U814856084B8.
Thank you for any assistance you offer.
DOT
Hi dotelvis,
Good day!
Thank you for getting back to us. Those LEDs are Power, Internet and WiFi. What are the colors of the LEDs? Please check ths link https://www.downloads.netgear.com/files/GDC/WNR2000V5/WNR2000v5_UM_20Nov2014.pdf
Please wired a computer using ethernet cable then check if you can go online or get an IP address from the router.
Oliver
Community Team
- dotelvisAspirant
As previously stated, the lights are NEON in color.
My computer has Ethernet from it to the router.
Hard to tell without knowing what you are doing and where it goes wrong.
The best way to update firmware is manually.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
dotelvis wrote:
...otherwise, Netgear will charge me $89.90 to help me!
Your router dates back to 2014. Netgear provides free support for the first 90 days after purchase.
This place is free.
- dotelvisAspirant
I have tried to download manually but I get an error message!!
