PowellRS's avatar
PowellRS
Follower
Oct 25, 2016
R6400 Router 5G AP not working
My 5G AP has stopped.
I have reset by removing power and paperclip in back.
SSID is enabled, (I have turned this on and off with no effect)
Region shows North America,
Channel is 149 (I have changed to seveal other channels with no effect),
Mode Up to 1300 Mbps ,
Shows Wireless AP as OFF (not sure why), I haven't changed anything and the 2.4G is working great,
Broadcast Name is On (I tried changing this also with no effect),
Wi-Fi Protected Setup is Configured, (I have turned it to None with no effect)
Thanks,
  • I managed to figure it out after a while. For some reason, the 5G was simply turned off, and I couldn’t find a way to turn it on via ythe NetgearGenie that was downloaded to my PC from the time I purchased the router. However, when I signed into the web-based Netgear Genie, I found the control to turn 5G radio on and did so. Then I reconnected my Roku and phone to 5G from the 2.4G.
    Thanks for the advice.
    Lee
  • Retired_Member's avatar
    Retired_Member
     try this
    read the manual regarding 2nd button from the right top front, this may been pushed by accident, it should effect both bands which is strange that only 5g is off
    or Push reset Until Power LED flashes, use default settings on router label...still bad replace it.
    • leesiegel's avatar
      leesiegel
      When I first got my router, both 5G and 2.4G lights were on. Then 5G stopped working (the light is out and I can see Netgear70-5G on my phone, just Netgear70 (which is the 2.4G).
      I have powered the router on and off. I have reset as recommended above. And I also tried turning the wireless light on and off. Still no 5G.
      Please help. I have a lousy cell connection at home and depend on 5G wifi calling. My call quality went to hell when the phone (Android Samsung Galaxy S7) started using 2.4G
