dougaday
Dec 17, 2021Follower
R6400v2 Can't connect to the router itself
R6400v2 Installed firmware update which caused delays in connecting to websites or wouldn't connect at all. Tried logging onto the router to check the settings but it wouldn't connect to the router. Did a factory reset and the website connection problems went away but I still can't connect to the router itself. routerlogin.net says "refused to connect". 192.168.0.2 says "took too long to respond". I tried .1 and .0 with the same results. Please note: I am not even getting the router login screen.
Any suggestions, please?
Thanks
you tried the default 192.168.1.1?
Whats it connected to for gateway?
Sometimes during setup it'll change its default if you're gateway is a modem/router combo device. Then it usually changes to the 10.0.0.1
- DUIduiAspirant
Also have this problem after installing firmware V1.0.4.122_10.0.95.
Ah ha.. another log in porblem!
Dougaday says:
The modem should be on the WAN side and the login GUI is on the LAN side, so what does the modem have to do with the inablilty to log in to the web GUI on the LAN side?
See more posts at:
- ng_usa_userAspirant
after I installed V1.0.4.122_10.0.95, the webgui/http server was no longer responding.
I power cycled and webgui returned.
