Pablo777's avatar
Sep 13, 2021
Router Problem with WIFI
Pablo777
Novice
I have Internet using Cat 5 cable but my other wireless divices like cell phones and TV's say:"Connected, no Internet. Please help.
Model: R6400|AC1750 Smart WiFi Router
  • Pablo777's avatar
    Pablo777
    Sep 16, 2021
    I bought a new router R6850 AC2000 and installed it correctly and all is well now. Thank you for your help.
  • plemans's avatar
    You have the R6400?
    What modem/gateway is it connected to?
    What firmware is running on it?
    Is this a new setup?
    Or what changed to cause this?
    • Pablo777's avatar
      Pablo777
      Tutor
      You have the R6400?  Yes
      What modem/gateway is it connected to?  Twin Communications
      What firmware is running on it?  V1.0.4.106
      Is this a new setup? No, but I had to reset the router because of a storm.
      Or what changed to cause this? If I need to cconnect a new TV or cell phone, I have to reboot the router before it will work on that device.
      On my main TV, it says "Connected, no Internet".
      • plemans's avatar
        Twin communications is a company.
        what gateway/modem is the R6400 connected to?
