m43999's avatar
m43999
VPN connects but no IP address for remote network
I have enabled VPN on the firewall and created the configuration files.  At remote site i have downloaded the OpenVPN client and installed the software.  The config files are copied to the appropriate folder.
The VPN Client opens and connects successfully and indicates that the connection is good.
When I check the IP config information i see that the VPN adapter has a 169.x.x.x address, meaning that it cannot get an address through DHCP.  In the connection log i see the following entries of interest:
Wed Jun 15 22:28:56 2016   server_network = 0.0.0.0
Wed Jun 15 22:28:56 2016   server_netmask = 0.0.0.0
Wed Jun 15 22:28:56 2016   server_network_ipv6 = ::
Wed Jun 15 22:28:56 2016   server_netbits_ipv6 = 0
Wed Jun 15 22:28:56 2016   server_bridge_ip = 0.0.0.0
Wed Jun 15 22:28:56 2016   server_bridge_netmask = 0.0.0.0
Wed Jun 15 22:28:56 2016   server_bridge_pool_start = 0.0.0.0
Wed Jun 15 22:28:56 2016   server_bridge_pool_end = 0.0.0.0
Wed Jun 15 22:28:56 2016   ifconfig_pool_defined = DISABLED
Wed Jun 15 22:28:56 2016   ifconfig_pool_start = 0.0.0.0
Wed Jun 15 22:28:56 2016   ifconfig_pool_end = 0.0.0.0
Wed Jun 15 22:28:56 2016   ifconfig_pool_netmask = 0.0.0.0
and at the end of the log file:
Wed Jun 15 22:29:01 2016 PUSH: Received control message: 'PUSH_REPLY,route 192.168.1.1 255.255.255.0,route-gateway dhcp,ping 10,ping-restart 120'
Wed Jun 15 22:29:01 2016 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jun 15 22:29:01 2016 OPTIONS IMPORT: route options modified
Wed Jun 15 22:29:01 2016 OPTIONS IMPORT: route-related options modified
Wed Jun 15 22:29:01 2016 ROUTE_GATEWAY 192.168.111.1/255.255.255.0 I=13 HWADDR=00:21:6a:89:7c:48
Wed Jun 15 22:29:01 2016 OpenVPN ROUTE: OpenVPN needs a gateway parameter for a --route option and no default was specified by either --route-gateway or --ifconfig options
Wed Jun 15 22:29:01 2016 OpenVPN ROUTE: failed to parse/resolve route for host/network: 192.168.1.1
Wed Jun 15 22:29:01 2016 open_tun, tt->ipv6=0
Wed Jun 15 22:29:01 2016 TAP-WIN32 device [NETGEAR-VPN] opened: \\.\Global\{212CD809-0DD9-4351-A973-CEAEEBEFD88D}.tap
Wed Jun 15 22:29:01 2016 TAP-Windows Driver Version 9.21
Wed Jun 15 22:29:01 2016 TAP-Windows MTU=1500
Wed Jun 15 22:29:01 2016 Successful ARP Flush on interface [2] {XXXX}
Wed Jun 15 22:29:06 2016 TEST ROUTES: 0/0 succeeded len=0 ret=1 a=0 u/d=up
Wed Jun 15 22:29:06 2016 Initialization Sequence Completed
Wed Jun 15 22:29:06 2016 MANAGEMENT: >STATE:1466054946,CONNECTED,SUCCESS,,xxx.xxx.xxx.xxx
Any ideas of why i cannot get an IP address on the remote network?  I have also tried assigning a static ip to the Netgear VPM adapter in the remote network with no success.
Sorry such a log explanation
M
  • m43999 Can you go ahead and update the firmware of the router?
    You may download the firmware and follow the instructions from this link.
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi m43999,
    Welcome to the community! :)
    What is the brand and model of the VPN firewall you are using?  If ever it is a NETGEAR VPN Firewall, what is the current firmware version of it?
    DaneA
    NETGEAR Community Team
      • ElaineM's avatar
        ElaineM
  • It is a Netgear Nighthawk AC1750 Smart WiFi router Model R6700.  I dont have the firmware version but i will work on getting that today.
