vnckramer
Jan 26, 2017Aspirant
WNDR3300v1 - Router not working
Our wireless connection went out, so I made sure everything was connected and restarted the router. This did not fix the connection. Then I check with our provider to see if our Internet connection was good and it was. I discovered that even when I plugged my computer directly into the router I could not get a connection. Is there a way to fix the router or do I need to get a new one?
It seems that you need a new router.
- vnckramerAspirantWe tried resetting the router and using a different power adapter but they didn't fixed the connection problem. We ended up borrowing a friend's spare router.
- ElaineMNETGEAR Employee Retired
- wcalifas831Prodigy
Try resetting your router and see if that helps. Also, you can try a different power adapter to see if that might be the culprit making your router unstable. Let us know what happens.
