DVE44's avatar
DVE44
WNR2000v5 Firmware Version 1.0.0.34 doesn't install
WNR2000v5-V1.0.0.34.img downloaded from NetGear Support on 2015-09-22 failed to install.  I am currently using v 1.0.0.28.
As an aside, checking for new firmware from the GUI, reports "No new firmware version available."
  • Thank you for your response.
    As per RonO, Genie also reported "No new firmware version available," when I checked for new firmware. I'm currently using v. 1.0.0.28. I again downloaded the zipped firmware from support using a different browser and tried to install the .img file using the same browser (Microsoft Edge, which replaced IE in Win 10).  I previously used FireFox. Still it would not update.
    BUT -- resetting the router did the trick. My router is now the proud owner of v 1.0.0.34! :)
    Thank you for your suggestions!
    DVE44
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi DVE44,
    Welcome to the community!
    Did you try to use a different web browser? Also, try to re-download the firmware just to be sure that it was not corrupted.
    If you can't still install, try to reset the router by using a paperclip to poke the reset button for 10 seconds.
    Resetting will erase all the settings, therefore you will have to reconfigure the router.
    Let us know what happens.
    • RonO's avatar
      RonO
      I have the same problem with ...34.  Also when I try to download it with the Genie it only offers ver ...28
      • ElaineM's avatar
        ElaineM
        DVE44 Thanks for the update! Glad to hear that it's now upgraded.
        RonO Will forward that to the engineering. For now, I suggest that you manually download the firmware and install it from there.
    • DVE44's avatar
      DVE44
      DVE44
