SNOW-DM
Dec 10, 2021Guide
2021 R7000 goes offline every couple of months
It's not even a year old yet. I've had the problem twice since October - suddenly computer says there's no internet - wifi router only has orange light on far left. Turning it off and on doesn't seem to fix. In October I had to go the reset route and finally got it working. This week it has gone offline twice - I find out when computer suddenly says no internet, after I've been using it for a while. It seems to take several shutdowns and restarts to get it working. I checked, my firmware is up to date, and on autoupdate.
VERY disappointed Netgear not willing to help unless they are paid (can't afford that) and I researched the product on Consumer reports and got recommendations from local computer shop that this was best option for my simple 2 computers, 1 phone, non-gaming, internet browsing, email reading, 3 zooms a week, occassional webinars lifestyle. I can't in good conscience recommend it to my friends whose routers will need replacing soon and are watching my experience... since it just randomly causes me hours of outage at inconvenient times with apparently no explanation or solution.
My previous Belkin router never had a single issue, until is stopped working due to old age incompatibility of some sort.
My ears are open if I've missed the fix!
- microchip8Master
Newest firmware version doesn't mean each time that it's the best. You can downgrade to an older version and see if it works for you. Then wait for future firmware that may fix your issue. Luckily, NETGEAR still supports the R7000
Well you didn't give us much to go off.
1. what actual firmware version are you on?
2. what modem/gateway is it connected to?
3. when it drops, do wired devices drop as well or just the wireless?
Something else to keep in mind is that this router was released in 2013. If people are looking for a newer router, this wouldn't be the one I'd recommend due to it being an 8 year old router. Was it solid/good performing in its time? Sure but again, that was a while a ago.
- SNOW-DMGuide
Well, really disappointed to hear maybe I didn't get the best option, and certainly didn't realize how old it was. I'm not an expert at this techy stuff, last time I plugged in the router and it just went until it stopped working. I was hoping for the same again.
It's the latest version of firmware that came out in September....
I talked to the internet company in January when I discovered I needed to replace the router, they said the modem was current, it looks to be an ARRIS TM1602 and has never given me any grief.
I have everything running wireless, so nothing connnects to internet when the router goes off.
So if I need to replace this one, what would you recommend for a nothing fancy reliable one?
I'm not saying its a bad router. For the vast majority of users, it can work great and does work great.
But it can have its issues.
And the auto-update server for the R7000 has never been reliable. Its why we usually have people log into the device to see what actual firmware they're on because they're are sketchy versions.
And if you don't like the firmware on it, the r7000 has a pretty large 3rd party firmware following if something like that interests you.
So to start off with, what actual version of the firmware are you on?
If you do change firmwares on it, I'd recommend a factory reset/reinstall. Some of the versions of firmware changed quite a few things and old settings can cause issues.
I'd also check the next time it goes down (could be months later) if it does work with harwired devices when it drops. that'd be another key detail
Which means that it is still covered by warranty if it has a manufacturing defect. (In some countries warranties last longer than a year.)
Start the RMA process by checking MyNetgear.
How do I request a Return Material Authorization (RMA)? | Answer | NETGEAR Support
Or use this place to get free lifetime technical support.
- SNOW-DMGuide
They don't consider it defective because it started working again. That's what I was told when I called in. They wanted $ to discuss anything more.
SNOW-DMwrote:
They don't consider it defective because it started working again. That's what I was told when I called in. They wanted $ to discuss anything more.I can see their point. Something that has happened as spasmodically as that may well be down to circumstances that have nothing to do with your router. The symptoms you describe certainly don't indicate a dead device. They could also be down to the internet service and/or the modem you use to connect to it.
Put a bit of effort into troubleshooting and you may be able to track down the cased of the problem. We need more detail than the description of your experience with earlier hardware:
My previous Belkin router never had a single issue, until is stopped working due to old age incompatibility of some sort.Sadly, " old age incompatibility of some sort" could hide many things.
And "latest version" is not helpful.
