tdcunningham
Nov 25, 2018Aspirant
AC2400 only lets device connect to Guest account
Netgear "customer support" is a never ending circle of nothing, so hopefully the community can help.
Just bought an AC2400 wifi router, it's running V1.2.0.32_1.0.1 firmware. I'm using 'Access Control' MAC filtering and successfully added (10) other devices.
One final device (a laptop) is unable to connect...to the primary (2.4G / 5G) SSIDs. However, it does connect to the 'Guest' login.
I've tried: turning both the laptop and router off & back on again; deleting and re-installing the laptop's wifi adapter and verified it has the most current driver; deleting and re-adding the laptop in the the 'Access Control' list; and disabling 'Access Control'.
Thoughts or ideas are greatly appreciated.
Just bought this router also had the same issue with only connecting to Guest network for wireless , I just simple unchecked the box for smart connect , for wirelessl , after that not a problem , router works great
- DarrenMSr. NETGEAR Moderator
Have you tried to remove the wireless networks saved in the laptops wireless settings then try to connect to the network again?
DarrenM
- Jojoe64Initiate
- Jojoe64Initiate
Also I forgot to mention , use the Netgear genie webpage on computer to change the setting , if you cannot connect to computer using wireless , plug a landline into your computer that is connected to your router , type into your browser 192.168.1.1 to access Genie webpage , login is '' admin '' password is the password that is on your router , or the one you created
- tdcunninghamAspirant
Thanks for the suggestion, I tried that after removing the wifi adapter from device manager, but it still didn't work.
Turns out the fix is unchecking the 'Smart Connect' feature that (supposedly) lets the router select the WiFi band.
