80roc80's avatar
80roc80
Connecting Xbox wirelessly to c7800
So I normally have my Xbox hooked up wired I moved it to another room and tried connecting via Wi-Fi have had it hooked up to Wi-Fi in the past and I had no problem now there’s no said to even see to Connect to when I try it says my security protocol won’t work, and that I am not hooked up to WPA/wpa2 which when I check my settings I am connected to WPA\WPA2
  • factory reset on the xbox?
    If its just one device having the issue, I'd be looking at that device closer
  • plemans's avatar
    Are any other devices having issues?
    Or just the xbox?
    are you using any special characters/spaces in the ssid/password?
    did you "forget" the network on the xbox and reconnect to it?
    anything else change in the C7800 since you had it wirelessly connected?
    • 80roc80's avatar
      80roc80
      All other devices are working and connecting fine, using same passwords /ssid. I have tried everything I can think of besides factory reboot
      • plemans's avatar
  • Did you notice any latency issues when changing to WiFi? My current router courses lag problems on most games when I change to wifi even though I am close to the router. New router on it's way soon so hopefully might be able to dich the cable
