Barryt100's avatar
Barryt100
HP Microserver not connecting to new router AC1900
I have a HP microserver.  t connects it through my router to my computer.  I have recently bought a AC1900 but I cannot access my microserver.  How can I connect my microserver to my computer through my router?
  • > I have a HP microserver.
       Does it have a model number?  Is it running some operating system?
    > I have recently bought a AC1900 [...]
       "AC1900" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the product label.
    >  Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
       Is that accurate?  Firmware version?
    > [...] but I cannot access my microserver.
       Whan you do what, exactly?  "cannot" is not a useful problem
    description.  It does not say what you did.  It does not say what
    happened when you did it.  As usual, showing actual actions with their
    actual results (error messages, LED indicators, ...) can be more helpful
    than vague descriptions or interpretations.  "access" is no better.
    > [...] How can I connect my microserver to my computer through my
    > router?
       Ethernet cables?  What, exactly, does "connect" mean to you?  What,
    exactly, would you like to do?
    > router?
  • That SERVER has an Ethernet Port which I assume you connected to the router.
    Now all you need do is SHARE that Server, just like any other PC. So what PC do you have and what OS is it running? Windows 10? You'll need to enable SMB1 to see a share. Probably need to set up the server to allow access by devices on your LAN as well. If you want External access, that has to be set up as well.
    Please explain what you've tried and what isn't working? Do you see the server on the router as a connected device on the LAN map?
    More info is really needed here to assist you.
    • Barryt100's avatar
      Barryt100
      My operating system is Windows 7.  I had an old router which was connected to my microserver.  Everything was working fine.  I upgraded my router to a AC1900 R7000 and now the router will not connect to my microserver.  When I go to my router I cannot see my microserver as being listed as a device. Can you help?
  • More questions, what other router did you have?. Are you replacing it or trying to add the R7000?
      Barryt100
      My old router stopped working so I replaced it with a AC1900 R7000.  My microserver worked with the old router but doesn't work with the AC1900 R7000
      • antinode's avatar
        antinode
        Guru
        > My operating system is Windows 7. [...]
           What's the OS on your (unspecified) "my microserver"?
        > [...] I had an old router which was connected to my microserver.
           What was the IP address of your (unspecified) "my microserver" then?
        If you configured your (unspecified) "my microserver" with a static IP
        address compatible with your (unspecified) "an old router", and it's now
        incompatible with your R7000, then that could explain much.
        > [...] When I go to my router I cannot see my microserver as being
        > listed as a device. [...]
           When you do _what_?  Are you looking at a "BASIC > Attached Devices"
        report, or what?
        > [...] I upgraded my router to a AC1900 R7000 and now the router will
        > not connect to my microserver. [...]
           With  my weak psychic powers, I have no idea how your (unspecified)
        "my microserver" is connected to the R7000, if the LED indicators on the
        R7000 and/or your (unspecified) "my microserver" indicate a good
        physical link, or how you configured the network interface on your
        (unspecified) "my microserver".
        > [...] Can you help?
           Can you provide some basic information?
