LOISLANE's avatar
LOISLANE
Initiate
Aug 05, 2020
Netgear Nighthawk R8000P Firmware Update
Firmware not updating manually nor via router web check option. Nighthawk R8000P Current Firmware Version: 1.4.1.50 Update Firmware Version: 1.4.1.62 I have attempted to update the firmware via the Router web app option when I select check for update the return message is no new update. However, there is a new firmware update. When I attempt to do it manually nothing happens even after a manual reboot of the router.
  • jmr33's avatar
    jmr33
    Sep 23, 2021
    I also was unable to update router firmware with the Nighthawk App, it would go for about 2 minutes, then fail, saying to "Try Again" later, which never worked. But it succeeded when I used a browser (FireFox) to 192.168.1.1 and chased it down that way.
  • I have the same problem, Firmware verison still shows V1.4.1.50_1.3.10 after after doing a manual update of V1.4.1.62_1.3.22.
    Ive tried doing a factory reset then updating, but it still doesnt show that it was updated.
    • kye4u2's avatar
      kye4u2
      Initiate
      I have the same issue.  I've attempted to manually upgrade to 1.4.1.62 from V1.4.1.50_1.3.10 but it still continues to display V1.4.1.50_1.3.10
  • Same problem here - in a way, im glad to know i'm not alone - even though it's still not a good situation..
  • I am having the same issue. attempted to the manual update several times with/without connection to internet/after reboot, no change. Still showing ver. 1.4.1.50.
    • shadowsports's avatar
      shadowsports
      Hero
      Start of my workday, wife and I are both working from home today.  I'll test this evening and post my results.
  • Same issue. It's actually causing packet loss on my internet by not having my router updated. Too bad netgear wants to charge me $80 **bleep**ing dollars to give me tech support. **bleep** that **bleep**.
    • Sorry for the delay.  New FW uploaded.  No issues here.
      Was no different than any other upgrade.  I didn't reboot or do anything special. Manual update from a system connected via ethernet.
      1.4.1.62_1.3.22
      Going to perfom my usual basic functionality tests now.
        shadowsports
        Hero
        Streaming 5G on 1.4.1.62_1.3.22 all day.  TV, XBox, Phones, several laptops...
        Wireless performance is extremely stable.
        Tested DynDNS
        Emailing Logs
        NTP
        IPv6 Support
        Connection to EX7000 extender also solid
        All looks good.  Pleased with the update.
  • Late to the party on this but here's my experience:
    Did the update through the NightHawk app. Got update error message and pushed the "Try Again" button. What was curious is that even though my Wi-Fi network still displayed on my devices, the network connection failed.
    I waited at least an hour to make sure the download and update was complete. However the router never booted. Last time I updated this router, it bricked and I had to to the manual update with this procedure.
    Thought I had to do it again so I took the chance to turn off the router, leaving it plugged in. Waited 10 seconds and turn back on via the push switch. Waited for the amber light to stay on but it fully rebooted and the version displays the latest firmware, 1.4.1.64 (see attached).
    I feel like I just dodged a big bullet. Just sharing a story and hopefully this incident could be replicable.
    • Greetings,
      You may have.  Several users have now reported an inability to upgrade.  1.4.1.50 > 1.4.1.62
      We haven't heard much about the 1.4.1.64 which I just uploaded successfully.  I was not affected by the issues and have used every FW version since 1.4.1.24.
      My cusory tests of 1.4.1.64 all passed
      Will evaluate wireless performance and stability today.
      Wired appears fine.
      • DR650SE's avatar
        DR650SE
        Guide
        Thanks for the notice.  I've logged into my Router and it's stating there is a firmware update available.  Tried to update via the routers browser and that does NOT work.  Tried via uploading the file as well as TFTP and those methods do not work either.
        Netgear has agreed to RMA my router.  However, My options are
        A:  Send the Router back, Netgear will send me a replacement once they recieve my router.
        B.  Pay $16.90 for Netgear to send me a product and a prepaid shiping label.
        I don't want to come across as a "Karen" or "Chad", but my item is still within the 90 warranty period.  Why should I have to pay to replace an item that Netgear has determined is defective?  And during a COVID environment, where me and my wife are working from home, and my kids are doing schooling online, I can't afford to wait for Shipping of my device there and back.  Who knows how long that downtime will be.  I sent a resonse requesting the fee be waived.  I hope I'm not coming across as unreasonable in this.  I try to remain respectful.
        My other option is to Return the R8000P to Best Buy where I purchased the extended warranty.  However I hesitate to do that because I had an R7000P that I purchased, and that had a physicall broken antenna.  Well the Best Buy warrenty replaced that.  The next R7000p worked for a year until it started kicking everything off my network.  So under the Best Buy warranty I decided to upgrade to the R8000P, which has been solid, but will NOT update firmware to patch security issues.  Working from home, I need ensure my data, and my works information is safeguarded.  Am I being crazy?
        /rant
        DESCRIPTION CHARGE
        Standard Swap Exchange - (North America only)
        This shipping option allows you to return the defective unit to the RMA fulfillment center. As soon as the fulfillment center receives the defective product, a replacement unit is shipped out in one business day via ground services. Customers are responsible for the shipping charges when shipping the unit back to NETGEAR. We suggest using a carrier that provides tracking information. NETGEAR is not responsible for packages lost in transit to NETGEAR. The replacement product is shipped by ground with shipping charges prepaid.
        Free of charge
        Advance Ground - Home Products - (North America only)
        The RMA fulfillment center will ship the replacement unit via ground before receipt of defective item, based on product availability. Your order must be received before 6 PM Eastern Standard Time. A prepaid shipping label will be included with your replacement unit. You will be charged a flat fee of $16.90 for Home Products and $19.90 for Business Products for this service option. You must return the failed product to the RMA fulfillment center within 10 business days of receiving the product. If you fail to return the product within 10 business days, you will be billed the current list price.
        USD 16.90
        Advance Next Business Day - Home Products - (North America only)
        For extra cost, Advance Priority allows you to receive the replacement unit the next business day, based on product availability. Your RMA number must be issued before 7 PM Eastern Standard Time. Along with the replacement unit, a prepaid shipping label will be included. Use the prepaid shipping label to return the defective product to the RMA fulfillment center. You must return the defective product within 10 business days of receipt of replacement product. If you fail to return the product within 10 business days, you will be billed the current list price. When your replacement part is shipped, your credit card will be charged for the amount below. You will be charged a flat fee of $29.90 for Home Products and $49.90 for Business Products for this service option.
        USD 29.90
  • I'm also not able to upgrage the firmware. Stuck on 1.4.1.50. Tried factory reset, update via app, hardwired login update via routerlogin, and even manually uploading the firmware file. Nothing worked.
    My router also often drops internet connection when I am browsing and reconnects 15-20 seconds later (sometimes I have to manually reconnect computer to wireless).  I bought the router on 8/15/20. I just got off the phone with tech support and also informed them of this thread with the ongoing issue. They said they will "offer me a call back while they investigate the issue." I am beyond frustrated with this router and Netgear's minimal support without having to buy a service contract.
    • RDel90's avatar
      RDel90
      Tutor
      I am now going on 3 weeks with an open support ticket with Netgear with no response. I have sent 2 follow up asking for an update but have not even been acknowledged.
      This is the worst customer support ever. Will never buy Netgear products again.
  • Hey all,
    Same issue with my R8000P. I’ve been a Netgear user for years but this is about to make me jump ship.
    • JMitchem's avatar
      JMitchem
      Initiate
      I've always had Linksys in the past. This was my first netgear and also more than triple the price of what I've had in the past. So disappointed. I'm waiting for the next firmware update to see if it will work. If not, I guess I'll just run it with this for a year then get another linksys.
  • Hi
    I am having the same issue discribed in this thread.  My Nighthawk R8000P shows firmware: V1.4.1.50_1.3.10 and "A router firmware upgrade is available" in the GUI.  As others discribe, the Firmware Update Assistant does return availability:
    New firmware is found. Do you want to update the firmware? (Yes) (No)
    Current GUI Language Version:1.4.1.50_2.1.46.1
    New GUI Language Version:1.4.1.66_2.1.46.1
    Current Firmware Version1.4.1.50
    New Firmware Version
    1.4.1.68_1.3.28
    However, selecting 'Yes' returns 'Failure' for the GUI Language update and returns to the 'Internet Setup' screen.
    I have also attempted the manual Router Update process by browsing to the downloaded R8000P-V1.4.1.68_1.3.28.chk file.  The process appears to complete with reboot of router, but the Firmware version remains as V1.4.1.50_1.3.10 and "A router firmware upgrade is available" in the GUI.  I have attempted this process in 3 browsers.
    Is there any hope here, or are these units just defective?
    Thanks...
    • RDel90's avatar
      RDel90
      Tutor
      Netgear finally gave me a return authorization. I’ll receive the new unit on Monday 1/25 and will update if it has the same issues or not.
  • So I paid the expediting fee and received the replacement router today (1/25). I was a little disappointed that is was a 'certified refurbished' unit. If a $300 electronic device has issues, it should at least be replaced by a new unit (especially if you only offer 3 months of technical support before you make customers buy a service package to get tech support over the phone after the first 3 months).
    Anyways, install was a PITA through the Nighthawk app which I tried first. Went pretty smoothly when I hardwired my laptop. Unit came with the .62 Firmware. After setup, I I was able to upgrade the firmware to the .68 while hardwired with no problems. Seems to be running smoothly so far. End of the day, looks like it was in fact a defective unit.
    We'll see how long it takes before this refurb unit has issues. I'll keep it running until then. But if it starts acting up, I won't hesitate to replace it with something else.
    • sghost42's avatar
      sghost42
      Initiate
      I am having this problem updating to the latest firmware.
      Currently at: V1.4.1.50_1.3.10
      Trying to go to: 1.4.1.68_1.3.28
      I called support, post 90 days.  Was told I get 1 free issue, then I would have to pay.
      I did the following over the phone with the tech:
      1.  Use firmware assistant to install - FAILED
      2.  Manually install the firmware (chk file) - FAILED
      Factory reset the unit
      3.  Use firmware assistant to install - FAILED
      4.  Manually install the firmware (chk file) - FAILED
      Was told this is a known firmware issue that is being worked on and expect to have a new firmware in a couple days.  Not expecting much, but still have the case open.
      • LOISLANE's avatar
        LOISLANE
        Initiate
        I gave up on the R8000P router the router is vulnerable to hack ect.. due to the lack of the security firmware patches.  I upgraded to the AX8 WiFi 6.
