davedave90's avatar
davedave90
Follower
Sep 16, 2020
Nighthawk R6700v3 - Whatsapp calls won’t connect
Hey everyone, I’ve seen over 100 posts about this but not a single solution.
I just got this router. Everything works well except Whatsapp.
I’m using iPhone 11 and every time I make voice or video calls on Whatsapp or receive calls and touch “answer” button, the internet connection stops working. I always have to switch to cellular data to be able to talk or video chat.
Is there any solution to fix this?
This doesn’t happen on any other apps. Only whatsapp.
Thanks,
Dave
  • I found out the problem is with IPhone. You need to go to your settings-WhatsApp-then enable local network for WhatsApp. This should work
    • Phi2bonnet's avatar
      Phi2bonnet
      Hey
      Any idea where to solve the same issue on Android WhatsApp? I didn't find the place to allow the network to run
      Thanks
  • Hi all,
    I am having problems receiving WhatsApp calls. The calls keep reconnecting and sometimes it just says poor signal and doesn’t work. The problem is with the R7000. I am surprised because I use Verizon Fios (fiber) and my speed tests reach 300 MBPS. The outgoing WhatsApp call are fine just the incoming calls have issues. When I switch from WiFi to Cellular it works well. I think Netgear should resolve this problem as I am not the only one complaining. Thank you.
    Ola
    • Dapsylaw's avatar
      Dapsylaw
  • I have the exact same issue. Ever since the IOS 14 update I can’t WhatsApp call through my Nighthawk R7000. It will keep reconnecting. If I call through FaceTime it works fine. If I call through WhatsApp using my XFi router in basement it works fine. Just no WhatsApp calls through R7000.
