trynkeepup's avatar
trynkeepup
Nighthawk X10 AD7200 LAN Ports Not Working
Hi everyone. First time needing to post anything. Bought R9000 — Nighthawk X10 AD7200 Smart WiFi Router from Amazon on 2020-08-08. The ports stopped working after a storm we had. My Xfinity modem had to be replaced after the storm. The Nighthawk's wireless is working great but none of the ports work for my wired devices. All fairly new cables.  Very similar to this 2018 post: https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Nighthawk-X10-R9000-LAN-Ports/m-p/1671893
The loopback test was successful. All ports lit up: https://kb.netgear.com/28408/An-Internet-or-LAN-port-isn-t-working-correctly-on-my-router-How-do-I-perform-a-loopback-test-to-check-the-port?language=en_US
I know it's out of warranty so I was hoping the community could share any tricks that might save me from having to replace it. I didn't do a factory reset since, reading through forums, it didn't sound like it would do anything. It's also on the latest version of firmware.
Thank you for any support you can provide.
  • Yep it ended up not being the ports, just everything that was connected. Replaced docking station, vpn hardware and NIC and it's working. Thanks for your help.
