newm21's avatar
newm21
Tutor
Feb 04, 2021
No internet connection r7000
I am currently recieving no internet connection through any devices through wifi. I have good connection when hard wired to Modem but when hooked back up to router I get nothing. I have reset the router multiple times. Tried different cables and everything. Not sure if the firmware needs to be updated but I cannot connect to the internet through the router to update the firmware. I tried the app and it cannot connect to the router as well. Unit is only a year and 2 months old. amazed that it can only last that long. any help would be greatly appreciated.
  • Its just checking to ensure the router is on the same ip address.
    did you try a different pc/laptop to access the router?
  • plemans's avatar
    What modem do you have?
    What caused it to happen? Firmware update? power surge? What happend?
    What are all the led's on the front of the r7000 doing?
    • newm21's avatar
      newm21
      Tutor
      I have a spectrum modem. Reset that as well. internet coming out is fine as I am replying to this hard wired to my modem.
      I am not aware of anything that happened. If there was a power surge it must have been extremly short as there was nothing else effected (no light flashing on microwave or anything else). I have not had a firmware update.
      The lights all look correct except for the internet light seems to be flashing. very subtle flashing compared to the other lights.
      • plemans's avatar
        You reset the router?
        Pushed and held reset for 7-15 seconds while its powered on?
        After a full reset, are you able to access the router through a hardwired connection (not using the app)
