achan000
May 25, 2018Aspirant
Open VPN not work on Windows 10
Hi support,
My R7800 open VPN did not work after upgrade to firmware 1.0.2.52. Error message as below,
Sat May 26 13:39:41 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat May 26 13:40:46 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat May 26 13:41:51 2018 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
How can I fix it?
Hi achan000,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- TerryPhVirtuosoDid you try to rest the router after FW uodate?
