daniel0615's avatar
Feb 29, 2016
Possible bug: ReadySHARE function R7000-V1.0.6.40_1.1.90
The ReadySHARE funsction do not work normally.
USB Functions->ReadySHARE->Available Network Folders
Can not use <Edit> <Create Network Folder> <Delete> button
Please fix the issue.
  • Hi daniel0615,
    I was able to use the edit, create network folder and delete buttons using the beta firmware. You have to make sure that pop-up blocker is not enabled in your browser.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi daniel0615,
    Do you get the same problem after resetting the router to factory default and reconfigure it manually?
      • JamesGL's avatar
        JamesGL
        Hi daniel0615,
        Let me check on this issue you have reported. For now, you may try reverting to v1.0.4.30 firmware or check other browser.
    • 01R's avatar
      01R
      Luminary
      i have a idea please if you are working on the firmware go get an xbox one and play gta online for days and have yr ip be ipv6 only the xbox one will be using 2 ipv6 addreses for DNS it wont use ipv4 at all  and see what happens
