jwong84
Sep 11, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June 2015.
As of 1.5 months ago, 2.4ghz band has been very intermittent, and at this point i was already using firmware 1.0.4.30. Rebooting the router did not do anything. I do not have any settings on the router except the ssid, password and channels.
I tried going back to firmware 1.0.4.28 and that only worked for maybe 2 days, then the disconnects started again. i have been using Wifi Analyzer app on my tablet just to see if there is a transmission signal from the router. 5ghz band has a constant transmission signal however the 2.4ghz band has an off to on time of maybe 3:1 at the best of times. This allows me to SOMETIMES connect to the router while on 2.4ghz band, but usually it will not connect. I have been forced to connect my desktop via a really long ethernet cable and older devices no longer have internet connections. I am currently still monitoring the off to on time and the worst as of yet is about 10:1. Basically the 2.4 ghz band is completely dead minus random spikes of it showing up.
I've seen a few posts with the 5ghz band issue similarly but no fix either. I used to have a wndr3700 and that worked fine until the range on the router out of nowhere and permanently dropped by about 25% causing me to buy a repeater to get coverage. Using the repeater solved the distance issue but then i had issues with connection speed (not huge but noticeable). I figured buying an R7000 would be a no brainer since its a top of the line unit and priced as such. I am very disappointed as i haven't been able to find a fix anywhere for this.
Any help would be greatly appreciated
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
- oertjeAspirant
All my devices on 2.4ghz do not work, hope there will be a solution quick
- oertjeAspirant
Thanx for the help, reset had result, but pfff all PF and other things must set. I have my modem in bridge, so I had 2 hours work.
- home_userAspirant
I am having the same issue. 5G is okay but 2.4G will not connect. Tried to change the wireless channel to EU, but the North America option is grayed out and will not allow me to make a different selection. Problem started today, immediately after upgrading firmware to V1.0.6.28_1.1.83. Tried reverting to the previous version, but have the same problem. Need to wait for Netgear to fix the bug?
home_user wrote:I am having the same issue. 5G is okay but 2.4G will not connect. Tried to change the wireless channel to EU, but the North America option is grayed out and will not allow me to make a different selection. Problem started today, immediately after upgrading firmware to V1.0.6.28_1.1.83. Tried reverting to the previous version, but have the same problem. Need to wait for Netgear to fix the bug?
No. You need to do a factory reset. See my post earlier above.
- bjtechTutor
A factory reset and manual settings re-entry does work. Mine's been running smooth since I did it over a week ago. Had the same initial symptoms, primary 2.4 wouldn't allow devices to connect, 2.4 guest and 5 both worked fine.
It's a real PITA, but I screen shot every page in "Advanced" settings (or you could take pics with your phone). Then reloaded defaults and manually re-entered all settings. For some, this might be an easy fix. For me, I have about 20 DHCP Reservations, 7 Port Forwards, and some security settings for my cameras that I had to re-enter. Took me about 25 minutes to reconfigure. Couldn't afford to wait, some of those devices are WiFi thermostats.
- stuckincubeApprentice
After daily failures, it's now been working for a couple days and the only change I made was to uncheck (disable) "Enable 20/40 MHz Coexistence". Let's see how long it lasts...
- tn77Star
Mmmm. I don't have that box checked.
As the error is intermittent, I'm still baffled about a factory reset "fixing" anything. At this very moment, everything works. But at any point things could fail.
stuckincube wrote:After daily failures, it's now been working for a couple days and the only change I made was to uncheck (disable) "Enable 20/40 MHz Coexistence". Let's see how long it lasts...
FAILED this evening. That setting didn't help.
Just pushing the hardware button (for 2 seconds) on the R7000 to turn off wifi, then waiting 10 seconds, then pressing it again to turn wifi back on fixes the problem and the devices can again connect to 2.4G. No other changes or anything else.
- brownfam1Aspirant
Has there been a solution? all of my ported devices are not working and do not have the capability to use 5G
- oertjeAspirantPush the wifi button . See above. I did it after fulltime reset en and then again Portforwarding alle my cams.
- KazzMANIAApprentice
Well, add me to the list. I did factory reset and rebuilt my router from scratch. I have simple setup too but have a nest thermostat and a wink home Automation hub that can only connect at 2.4ghz. Before the factory reset, my issue was exactly as described throughout this thread: perfectly reliable 5ghz and direct wire but 2.4 would just drop and devices could not connect. The devices still see the 2.4 and seem to pass it an acceptable password but keep waiting for ip to be issued. Also, I have tried turning on and off wifi switch - no change in reliability. Rebooting router or toggling the wifi on/off hard switch on the router restores 2.4 functionality but only for a while. Issue occurs again usually within 24 hours. Fails for all devices. Also fails when 5ghz is disabled. Fails with and without password protection. Fails with one device connected, 7 devices connected, or no devices connected. Watching the netgear genie app after it fails, the 2.4ghz network disappears and reappears randomly and rapidly then suddenly settles down and is visible (but not usable) for several minutes then, bam, starts hopping in and out of existence again. I have witnessed this sane behaviour when scanning for wifi using two different smart phones. After rebooting router, 2.4ghz is always visible and connectable. And, when it works, it works great. Very good signal strength and very good distance. I have moved this router to a different floor of my house - exact same issue. When I drop the router and turn on my old trendnet I have no problems at all. I need 2.4ghz to run home Automation including my thermostat! For $200, this thing is useless to me, and I have spent almost 8 days and about 40 hours wasted testing it. Worse still, I was on with tech support and they told me I had a bed radio and needed to return it to Amazon. Uhhhh, sounds like everyone is having this issue so replacing it is not going to help. NETGEAR YOU ARE KILLING ME. please help
The good news is that, as reported by JamesGL in an above post, "The issue has been reproduced by support team and has been forwarded already with the documentation." So now we just wait for the fix.
It is concerning that when you called Netgear tech support they had no info about this issue and just told you to return the router. How many people are getting this advice? Why hasn't Netgear phone tech support received a notice or bulletin advising them of a confrimed issue with the router that is being worked on? Maybe JamesGL can comment on that!
- KazzMANIAApprenticeYes, and I spoke to support late yesterday. I only stumbled on to this thread last night.
I just called support again. They do not have this issue in their first-tier support database. They got me to use channel 11 (already tried - no change in result), and had me change fragmentation length and CTS/RTS thresholds each to 2304 (have not tried yet) and the reboot router. It worked (but rebooting router always gets 2.4 back up). Said he will make notes but cannot escalate issue unless it happens again. Usually takes 4 to 36 hours for 2.4 to fail so I should know in next two days if this change solves the issue (very doubtful) or has me sending this router back. I'll let you all know either way.
- JamesGLNETGEAR Employee Retired
So, after I made the changes to the router settings described in my previous post, the the 2.4Ghz remained perfectly reliable and ran without incident for 30 hours. However, shortly after I made the changes, I noticed that the my netflix was buffering a lot more than usual. I have a 50 megabit ISP that can peak at 70 megabits so I knew something was up. I used speedtest - ran it about 30 times from two different PCs on my network (using Ethernet connection) and on several wifi devices connected via 2.4 and 5Ghz. If you can believe, the wireless results were between 45 and 50Mbts on 5Ghz and about 20Mbts on 2.4, which is expected. However, my ethernet connections all tested at 0.2 to 1.4Mbts - WAYYYYY slower than it should be. I bypassed the router and went direct into modem - got to 48Mbits minimum speed and bursted well of 50. Ran about 20 tests over an hour and tried hitting different servers: exerienced some variability but very little and all within expectation. I connected router (without rebooting) and went back down to about .02Megabits. OUCH. Rebooted router and modem. Ran tests again. Exact same. I undid the settings I changed (described in last post), rebooted router and modem. I recovered my performance in LAN but the 2.4Ghz modem fell off again. I called support, we spent 2 hours running every conceivable test and, in the end, they decided that there was a problem with the router. Durring this period, my first teir tech was talking with his backup support (teir 2) and he told me that this router might suffer from being made with parts that did not meet design specifications. He offered RMA. I went to Best Buy and bought another identical router (original was purchased from Amazon). Plugged it in yesterday, configured it exactly as I had originally with the first router (nothing fancy), ran two hours of tests. It was perfectly stable and FAST and has been running without issue for about 40 hours now. The model numbersare identical on the two routers but one I had all the trouble with has a serial number starting 44475B and the new one from Best buy (and that works perfectly) is 44475C, suggesting that it was made at a later date and therefore might benefit from containing different components or at least same components from a different batch. Therefore, I conclude that what the support rep told me is likely true: some of these models include parts that function but which do not meet design specs and, the result of this is that the router manifests easily producable and unexpected issues not usually identifiable until the modem is deployed and the issues cause noticible trouble. Lots of people might not have even bothered to test the speed of their modem and, if they had, they might have assumed it was the ISP. Now that I have a fully functional version of this router I am both happy and impressed. Too bad I had to outlay so much more money for the replacement and also had to spend about 40 hours over 9 days and talk to four different support reps to learn the truth of the matter. On the plus side, I found netgear support easy to access and seemed committed to heping me resolve the issue.
- KernaldGuide
Well then, I guess mine will go in for an RMA too. Thanks for your time!
- KazzMANIAApprenticeJust out of curiosity, what are first 6 digits of your serial number (starts 444)?
- KernaldGuide
Well, I don't have any 444 in my serial number. I bought it in France, if it matters. First six characters are 3LL142.
