jerow23
Dec 07, 2023Aspirant
R7000 5G Band is not showing
Ask :
My 5G band on my R7000 firmware V1.0.11.126_10.2.112 is suddenly disappear. I tried most of the similar solution in the community but same result.
1. I reboot the router by power off and un-plug the power wait 3 minutes and turn back on
2. I restore the router to factory setting by go to the router page -> advance --> Administration --> backup setting -> Erase
3. Enable Disable smart connect
4. Enable / Disable SSID broadcast on 5G wireless network
Any suggestion that i might missed?
ps. the led on 5G is sometimes solid, sometimes blinking
Thanks
There have been half a dozen new releases since your firmware:
R7000 Firmware Version 1.0.11.136 - NETGEAR Support
What tells you that the 5 GHz wifi has disappeared?
ps. the led on 5G is sometimes solid, sometimes blinkingThat is a sign that the wiofi is working. Blinkin = traffic.
Do you have Smart Connect enabled?
If so, you will not see separate SSIDs for 5GHz.
As the manual puts it:
Smart Connect selects the fastest WiFi band for your device. For Smart Connect to work, the 2.4 GHz and 5 GHz bands must use the same WiFi network name (SSID) and network key (password). That means that when you connect to the router with WiFi, you see only one SSID that connects to both bands.
- jerow23AspirantAbout the new firmware, i tried to do “check update” from the router and it says firmware is updated. Does it means i need to manually install the firmware?
I cant see any 5G network on my devices to connect to, not in my phone, wife phone, my 2 laptops. However i can see my other access point 5G network, so i assume its not the device, but the router.
Smart connect is disabled, still i cant see the 5G network from the R7000- michaelkenwardGuru - Experienced User
jerow23 wrote:
About the new firmware, i tried to do “check update” from the router and it says firmware is updated. Does it means i need to manually install the firmware?Yes. If your first message was correct on the firmware version, install the firmware manually.
The router's on board check is not reliable.
Your first message said "Enable Disable smart connect".
Which is it?
I cant see any 5G network on my devices to connect to, not in my phone, wife phone, my 2 laptops. However i can see my other access point 5G network, so i assume its not the device, but the router.You will not see any 5 GHz wifi networks from the R7000 if you have Smart Connect enabled.
Have you looked at the status of these devices to see which wifi band they are talking to? They may have connected to 5 GHz wifi without you know it.
- jerow23Aspirant
I Finally at the latest firmware on this model Firmware Version
V1.0.12.216_10.2.122However seem my apple device (2 iPhones, 1 laptops) can not see the 5G network.
I tried sharing the wifi connection by using my android device (which can connect to the 5G network) by scanning the QR code generated by the android device. But my iOS shows "connection unsuccessful"
Any other way I should do?
Try factory resetting the router and setup from scratch with a ethernet connected PC?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
- jerow23Aspirant
I will try to find some time doing it.
It's strange tho, If I want to blame my iOS device, this same iOS device can see and connect another 5G band from another wifi router (TP Link).
If I want to blame the R7000 Router, my other android device can see and connect to R7000 5G band, even my TV can see and connect to it.
