kmcghghy
Feb 19, 2015Novice
r7000 drops internet connection
I've been reading reviews now and it appears now that the following is a known issue that they just refuse to fix.
I've been an IT System Administrator for over 20 years and I would not buy another Netgear product again after dealing with their support which doesn't admit there is a known problem.
I had the Netgear WNDR3400 and never had any trouble with it. I bought the Nighthawk R7000 and for $200 and my experience with other Netgear hardware I thought this unit would be great.
I have had nothing but trouble with it. The Nighthawk r7000 is constantly going down. I upgrade firmware and it craps out and I have to redo the configuration. I get up in the morning and no wireless, I have to reboot it. Sometimes it goes down 2-3 times a day. The other day I got up and again no wireless, I rebooted and that didn't fix it. I go into the configuration and it says the wireless is turned off. First time I had this issue and you have to hold the wireless button on the front for about 10 seconds to turn it back on.
This is ridicules that this unit has so many issues. Of course it's now out of the 90 warranty and Netgear says as long as the correct lights are on it not a
hardware issue so pay us to troubleshoot or fix it yourself. When the device is a lemon, you can't fix that!
NOW THAT I’M WRITING THESE REVIEWS, I FIND THAT USERS HAVE THE SAME ISSUES I’M HAVING. THEY HAVE ALSO CONTACTED NETGEAR TO NO AVAIL.
BOTTOM LINE, BUY ANOTHER PRODUCT.
- Retired_MemberMar 03, 2015If the firmware was at fault I would think all of the r7000 out there on the same version would be affected. I use a R7000 and just yesterday re-installed 1.0.4.18 and then manually entered my settings.
I don't use the USB port, genie, QOS or media sever. This is the first time I configured it offline using a wired connection for the whole process not just the FW portion.
As for the WIFI button, While I setup mine yesterday I pushed it for a few seconds and both radios turned off. I entered all my settings and rebooted and power cycled several times and the radios stayed off as expected. When I finished entering my settings I turned the router off and installed then powered back up then had to push the wifi button to turn on the radios. 24 hours later all is still good, VPN to work stayed up and 27 devices are all connected. I also have a AP at that opposite end of my 3000 square ft home and no devices jumped ship to it in the past 24 hours which if the WIFI was turning off I would see some clients attaching in the AP log.
Not all problems are FW related. I would and have numerous times suggested contacting support and getting a replacement.
Tell them it's dead and pay for a advanced replacement.
- ShawkatAspirant
I agree to all R7000 is without a doubt a faulty product. I have bought this product 4/5 months back and ever since this has been problem. I have upgraded to the latest firmware and have done factory reset several times but the it constantly drops connection almost every 20/30 mins. I use Linksys EA4500 as a back up router which works like a charm. I have done lot of research on this product and tried many suggestion I could find without any luck. I diont think Netgear can ever convince me again with their fancy words to buy their product again.
- doraemonProdigy
Mine still works.
- culero23TutorThank you for posting this. I will try not to upgrade to the latest firmware. I'm afraid my router will start having issues again.
- JamesGLNETGEAR Employee Retired
Hi gavster,
After you reset the router, did you manually reconfigure the router or loaded the back up settings?
- jakeduffAspirant
Beyond frustrated and I will NEVER buy another Netgear product again. We bought the r7000 to replace an older/lower end Netgear unit that failed due to product lifespan and thought I would spend the money to get the higher end model. r7000 has been nothing but trouble with constant drop offs; Google r7000 and look at all the complaints. I work as senior management in business and have never seen such terrible customer service and failure to address a major issue with their product.
- VE6CGXMaster
Sounds like you got a sick router or AC power adapter(known to happen many times). When I had R7000 it just worked with Kong's
dd-wrt firmware so well.
- JhtAspirant
I have exactly the same problem..... Spent 3+ hours with Netgear tech support - must be in India - each time I have to repeat the same explanation and go through the same steps. Upgraded firmware - changed router to channel 10. Finally they suggested a replacement. Replacement arrives EXACTLY the same issue.
I will never buy another Netgear product again.
Packing up the second ex7000 for return.
- culero23Tutor
Same issue here. How do I check the logs to see why it drops connection. Not sure if it drops conecction to the modem or drops the conection for the wireless users. But all my devices are through wifi and they lose connections a couple of times a day.
Im running latest firmware which has not resolved the problem.
Thanks
- culero23Tutor
By the way I refuse to buy a new router. I was hoping this one that cost so much was going to work better. This is my last Netgear I'm getting if no resolution is found.
Hi culero23,
What is the exact firmware version loaded on your router? If it is v1.0.6.28, you may revert to v1.0.4.30. The firmware v1.0.6.28 was pulled out from support site.
- rdlkglidersAspirantYes all the above accounts of the r7000 dropping connecion are issues experienced by many. It is way to expensive to be this laborious to maintain connection. I am mot going to elaborate but in short the unit is troubled and disappointing.
MCP, CompTia A+ Hardware & Software certified Tech- WeyldfalconAspirant
Same problem, have we found a resolution yet?
- doraemonProdigy
Just like others, still waiting for an official firmware fix.
- wesley410NoviceI have the same problem. I had it with the factory firmware and I have it with DDWRT. I was using the VPN server feature of the netgear genie, and with DDWRT i am only using basics, usb enabled, and syslog enabled.
Something is not right. I am always dropping my live feeds for class and I have been afraid to try taking a test at home.
Since both firmwares have the problem it has to be hardware related or some poor driver support.
For the record, this router is mounted on a wall with only 32" of clearance all the way around. Sorry, but that was the best I could do until I hit the ceiling.
Intermittent problems are the hardest to troubleshoot. The Netgear logs did not show anything.
The DDWRT logs only show this: ddWRT kern.info kernel: nvram: consolidating space! however, I cannot correlate that entry with the times WAN connection drops. - Retired_MemberIf the firmware was at fault I would think all of the r7000 out there on the same version would be affected. I use a R7000 and just yesterday re-installed 1.0.4.18 and then manually entered my settings.
Tell them it's dead and pay for a advanced replacement. - FairytailVirtuosoIf wireless turns off by itself, you might want to check the wireless schedule if it is enabled.
http://kb.netgear.com/app/answers/detail/a_id/24102
