jimmyk8's avatar
jimmyk8
R7000 Speed issues
Good Afternoon,
I have noticed that over ther past month my WiFi has been dropping and the speed is not what it should be.
I have Xfinity 75/10 speed.
When I checekied today I was getting between 3-18 downlaod speed.The odd part is that upload is always 12.
I reset everything and it did not improve.
I thought a firmware update would be the best choice. I was unable to do an automatic update. The online portal kept telling that it could not connect to the netgear servers.
I downloaded the file from netgear and I am now on Firmware Version V1.0.7.10_1.2.3
I still have the same issues hardwired to the router or via WiFI.
Direct connected to my modem I get 80 d/l speed.
Are there any setting in the advanced section that I can changed to pass through the full speed?
Thank You
James
  • jimmyk8's avatar
    jimmyk8
    Mar 19, 2017
    Thank You very much all for the support.
    This mornign I went through more firmware changes to no avial. I went back to verify that to the modem was still good, it was not.
    I called xfinity, they had to make a change on their side, noting that I needed to get up to date firmware from motorola on my modem.
    All is well.
  • PC Speed Test
    Above is my PC Speedtest
    Below is my Mobile speedtest
    Mobile Speedtest
    • jimmyk8's avatar
      jimmyk8
      I forgot to note,
      I did a full reset after the firmware upgrade did not solve the problem.
