SolitaryWolf
Feb 21, 2016Aspirant
R7000 wifi is not working correctly?
Hello, Recently I have changing my router's firmware from Tomato to the original netgera firmware since I did not need that Tomato stuff. I beleive I have done so correctly since I followed a vi...
- Feb 21, 2016
For some reason I simply reset the router, hard reset and start from scratch but still has the newer firware (1.0.6.28). Oh well, it works either way.
TheEther
Feb 21, 2016Guru
Sounds like you are running 1.0.6.28. Netgear pulled it due to bugs. Downgrade to 1.0.4.30 and wait until Netgear issues new firmware (ETA 1 week).
Retired_Member
Feb 25, 2016How accurate is the "ETA 1 week" ? I had to roll back to 1.0.4.30 but find I'm getting mediocre performance from 2.4Ghz and Lan-To-Lan file transfer.
And yes, I reset the router and aplied default setting etc after 1.0.4.30
I had high hopes for the R7000 but if this is the Q/A that comes out of Netgear regarding firmware, I'm ready to dump it and go for another brand.
- JamesGLFeb 28, 2016NETGEAR Employee Retired
Hi MikePoullas,
If you are interested to try the beta firmware you may check the link below.
- Retired_MemberFeb 28, 2016
Thanks but I sold my R7000. as a remote worker I need my router to WORK. I have no time to play around with Beta's.
Going back to an Apple Airport Extreme that while it doesnt have all the "flashy features" actually works..Good luck!
