fastcore's avatar
fastcore
R900 security updates took me from 400-600mbps up/down to ~3mbps down 0.1 up - firmware V1.0.5.40
About a week or two ago I saw there was an security update for my router. It had done a bigger update automatically maybe a month ago but this last one just ruined my network speeds.
Firmware V1.0.5.40 is what I'm on now.
Should I roll it back in firmware? Confirmed network is fast on the other side of it. Wireless is mostly affected but having similar issue wired now. No other network changes other than the firmware push. I had two wireless fans put in a week before the firmware upgrade but that didn't degrade my network like this had.
Never had an issues with the router before and my fiber speeds can creep down to 100mbps but nothing THIS bad.
  • What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
    What devices are you using to speed test with?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • This is my current speed over wired
  • FURRYe38's avatar
