perryalbright21's avatar
Nov 23, 2025
R9000 2.4Ghz & 5Ghz stop working
I had bought this device in January and preconfigured it before we shipped it to a Missionary House in Honduras. The Wifi 2.5 and 5Ghz stopped working and their leds are off.  The firmware was updated from V1.0.2.40 to V1.0.6.46 and now to wifi connectivity.  The hardware RJ45 network ports in the back all work.  Any ideas on how to resolve this issue.  I am not having good assistance with their technical support team.
  • CrimpOn's avatar
    CrimpOn
    Assuming that the WiFi LED button is "on" (page 13 of the user manual)
    i.e. the LED is LIT.
    The 2.4G, 5G, and 60G radios should be on and broadcasting the defined WiFi networks.  Any WiFi Analyzer application or program (such as WiFi Info View, free for Windows) should detect them.
    If the signals are not detected, then the router is not working.
    • perryalbright21's avatar
      perryalbright21
      Working with technical support team and it has a hardware failure inside of the unit.
      • FURRYe38's avatar
        Something you can do, disable the wifi radios on the router and install a external ethernet connected wifi AP.
        Good Luck.
