unkerjay's avatar
unkerjay
readyshare mount error(13): Permission denied
I'm using Linux Mint 18.1 Mate.  This WAS working.
Used: sudo mount -t cifs //###.###.###.###/USB_storage /media/public -o sec=ntlm
Prompted for password and I'm in.
That's NOT WORKING anymore.
Nothing I've tried seems to work.
I'm NOT using Windows, connecting to ANYTHING Windows.  This is STRICTLY a LINUX problem.
I CAN connect directly to the USB drive.
In, plain english (please), what can I do to troubleshoot this and fix it?
Thanx
  • Ok, I've tried recommendations from the sidebar (excepting those for Windows as noted).  I've tried what I've found on the web.
    And I've tried shumaku's recommendations.
    NOTHING has made a difference.
    So, I've connected it to a remote laptop and will access it from there when I remote connect to that laptop.
    Either that or I may try USB over IP on a raspberry pi I've got set up in another room.
    Readyshare works great, when it works.
    Thanx
  • schumaku's avatar
    schumaku
    Hm, not sure ... was this command line copied? Isn't the default share of the first USB drive /USB_Storage ?
    Without authentication required:
    # mount -t cifs //192.168.1.1/USB_Storage /mnt/readyshare/ -o guest
    With a username and a password (another shared folder on the same Nighthawk):
    # mount -t cifs //192.168.1.1/other /mnt/readyother -o user=admin,password=password,sec=ntlm
    If uncertain, try --verbose or -vvv ...
    # mount --verbose -t cifs //192.168.1.1/other /mnt/readyother -o user=admin,password=password,sec=ntlm
    mount.cifs kernel mount options: ip=192.168.1.1,unc=\\192.168.1.1\other,sec=ntlm,user=admin,pass=********
    You might want to provide the password on the command line - still specifying a username is suggested:
    # mount --verbose -t cifs //192.168.1.1/other /mnt/readyother -o user=admin,sec=ntlm
    Password for admin@//192.168.1.1/other:
    If you are using the same username, you can do it without the username:
    # mount --verbose -t cifs //192.168.1.1/other /mnt/readyother -o sec=ntlm
    But wait, you are sudo ... and then you become root
    # sudo whoami
    root
    Hope this gives some ideas. And then ... I've seen Linux distros breaking simple NFS mounts as well as mount.cifs.
    -Kurt
    • unkerjay's avatar
      unkerjay
      Thanx
      • schumaku's avatar
        schumaku
        The ReadSHARE is a plain simple (and outdated, vulnerable, ...) SAMBA 3.0.24 serving SMB 1.0 protocol, and max ntlm auth security on all Nighthawk routers.
        Well, I'm still convinced it's either a problem between keyboard and chair, or a problem with your Linux distro, the SAMBA Kernel module in place, the SAMBA utilities in place, ..
  • I checked my permissions.
    I reset them using:
    sudo chmod -R 777
    I then went in and tried modifying files and I double checked that the permissions settings
    matched the chmod.
    Check on all counts.
    I checked the permissions and chmod on the folder to which I was assigning the networked drive.
    Check.
    So, I'm running out of locations for checking the appropriate permissions.  Something I missed?
    (Apparently.)  What?
    • unkerjay's avatar
      unkerjay
      P.S.  I'm here to try to solve a problem.  Not to win a popularity contest. So, all the notifications to my ego
      aren't working.  And this probably won't help.
      Just saying.
