i58_Jess's avatar
i58_Jess
Select ethernet name on an R7900P Router
When I connect an ethernet cable to this router, it defaults to Netgear93; can I select a different name?  If so, how?
    • i58_Jess's avatar
      i58_Jess
      Win11 shows that I am logged into Ethernet to Netgear93.  At the same time, I am logged into Wireless SSID i58 (one that I created).  What I want to do is log into Ethernet i58 not Netgear93.
      I am currently logged into the R7900P.
      • FURRYe38's avatar
        Disconnect from the SSID on the router or disable the wifi radio on the laptop.
        You should be only connecting to one or the other at separate times.
  • michaelkenward's avatar
    michaelkenward
    Try this, go into the router and change its name.
    In the browser's graphical user interface (GUI):
    • Advanced
    • Setup
    • LAN Setup
    • Edit the name
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Change the Router’s Device Name
