rnovak1624's avatar
rnovak1624
Unable to log into router C7000
Yesterday it was working fine, but today, when i open up the genie software, the router login window pops up.  user name is force to admin which is what i want, but i type in password and press login, and login window disappears for several seconds and then pops up again.   this just repeats and repeats.   i can hit cancel, and i get then view things on the network, but i don't have the option to change anything.   i uninstalled and reinstalled app and still  same thing.  I can go to a browser and log into the router using same admin and password, but would like to use the genie again if possible.  Any ideas what could be going on or is there something better than the genie?
  • additude's avatar
    additude
    Apr 01, 2020
    There is not a way to "move" it however you can post here with a link to the new post that you have started a new discussion at that location.
    However, one thing I would "verify" at this point is that if you return your setup to it's original configuration without the extender will the problem go away or stay.
  • A bit more information.  when I click on the router settings tab, a login window pops up with information filled in, but the login button is greyed out, the cancel button is blue.  cursor spins for several seconds and then wireless settings tab opens, but no information is shown, and a message appears at the top that operation has timed out.  This is on a windows PC that has has the genie installed and running fine for at least a year.
  • michaelkenward's avatar
    michaelkenward
    So, the modem router is working OK, but the desktop genie is bust? Is that right?
    Is this PC wired to the modem router or using wifi to connect?
    These various popup windows, are they a browser? The genie? Something else in Windows networking?
    What version is the genie?
    You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
    Cable Modems & Routers
    • rnovak1624's avatar
      rnovak1624
      the modem router is working fine.  it's just the genie.   This PC is wifi connected.   the popups are within the gene software.   genie version 2.4.62.   i've tried to update, and it tells me i have the latest version.   This software used to work great for a year.   I recently installed a netgear ac1900 wifi mesh extender, model no ex6400 and after doing that is when the issues with genie started.  Yesterday morning, the genie software was functioning normal and no popups and i had full access.   This morning, back to the popups and basically only view authority.
