StanH
Feb 15, 2017Tutor
With Readyshare Vault, how can I exclude one individual file from backup?
Yes - that is correct and a commonly used technique.
Again, just to confirm, I'm responding with regard to ReadyNAS Vault. Can you confirm you are using ReadyNAS Vault (as opposed to ReadySHARE Vault)?
- JennCNETGEAR Employee Retired
Hello StanH,
I am responding to you this post to keep this alive and get ReadyNAS Vault people see your concern.
- ReadyNAS-VaultApprentice
Hi StanH,
I'm not sure if this is about ReadySHARE Vault (backup solution to hard drive attached to your router) or the ReadyNAS Vault (the cloud backup solution built-in to ReadyNAS devices and usable on other hardware like laptops and desktops). I'm only able to provide guidance on the latter, as a member of the ReadyNAS Vault support team.
If you are confused about which service, please check this grid: http://kb.netgear.com/23703/What-is-the-difference-between-the-NETGEAR-ReadySHARE-Vault-and-the-NETGEAR-ReadyNAS-Vault
Here are two related support articles detailing how to add exclusions your ReadyNAS Vault backup jobs.
http://support.readynasvault.com/hc/en-us/articles/208283106-Web-Portal-Creating-Modifying-Backups
If you need any additional help, just email us directly at [email protected]. One of our team members will respond and help over email or set up a screen share if necessary.
- StanHTutorIt sounds like I could exclude specific files excluding a folder and by putting the file or files in it. Is that right?
