triela
Jan 23, 2024Aspirant
M4300でのVLANについて。
一般的なVLAN設定についてですが、設定方法によって異なるので混乱しております。 show runから情報からですが、まずvlanの設定方法は以下のような設定になる事があると思います。 (*設定例なのでポート事異なる運用でなく、Switchmodeの設定とPVID設定が混在する事が望ましくないことは確認しました。) まず・・ Q1: 一般的にというのか、どの設定が正しいものでしょ...
triela
Re-described in English
I am confused about the general VLAN configuration, as it depends on how it is configured.
From the information in the show run, I think that the vlan configuration method can be as follows.
(*I have confirmed that it is not desirable to mix switchmode settings and PVID settings, not to operate different ports, since this is a configuration example).
First...
Q1: What is the general situation?
In general, which settings are correct?
1/0/1 is the result of the GUI setting,
1/0/2 is the result of setting "auto 1" as "exclude 1" in the CLI,
1/03 is configured in swithport mode access.
Basically, as a result, the fact that it belongs to vlan 10 is
The result is the same from "show vlan 10",
From "show vlan 1", only 1/0/3 is configured as "Exclude" instead of "Autodetect".
interface 1/0/1
vlan pvid 10
vlan participation auto 1
vlan participation include 10
Exit
interface 1/0/2
vlan pvid 10
vlan participation exclude 1
interface 1/0/3
interface 1/0/3
switchport mode access
switchport access vlan 10
exit
Please let me know if you have any further concerns from the above configuration.
Q2: What is the problem with the
Is there any difference/problem in being autodetect (≈vlan participation auto 1) and setting it as exclude?
Q3: Next, what is the difference between "switchport" and "vlan participation auto 1"?
Q3: Next, when configured with "switchport mode access", Ingress Filtering is enabled. Other settings will disable it."
Q4: What is the difference/issue with the "switchport mode access" setting and the "switchport mode access" setting?
Q4:.
When I set "vlan participation exclude 1", Forbidden VLAN is set to 1. The others are None.
What does Forbidden VLAN mean?
Netgearアカデミーでスキルを向上 - トレーニングを受け、認定を取得し、最新のNetgear技術で周囲と差をつけよう!
参加はこちらから!
