JohnNulty
May 24, 2016Apprentice
Android Mobile ReadyCLOUD app battery drain
I just thought I'd mention something I have noticed about the new ReadyCLOUD app (ver 1.2.3) for Android. I use a Nexus 4 phone and last week loaded the app as part of my tinkering, after the upgrad...
ljung
Aug 18, 2016Tutor
Yes I do, the media(photo) backup feature is what I use this app for. But it's not always running in the task switcher (maybe somewhere in the background)
- JennCAug 23, 2016NETGEAR Employee Retired
Hello ljung,
Have you checked if it still uses that high percentage when there is no backup running on the ReadyCloud app?
I personally have this app installed on my phone and not getting this battery drain problem.
