JohnNulty
May 24, 2016Apprentice
Android Mobile ReadyCLOUD app battery drain
I just thought I'd mention something I have noticed about the new ReadyCLOUD app (ver 1.2.3) for Android. I use a Nexus 4 phone and last week loaded the app as part of my tinkering, after the upgrad...
ljung
Aug 18, 2016Tutor
Yes I do, the media(photo) backup feature is what I use this app for. But it's not always running in the task switcher (maybe somewhere in the background)
JennC
Aug 23, 2016NETGEAR Employee Retired
Hello ljung,
Have you checked if it still uses that high percentage when there is no backup running on the ReadyCloud app?
I personally have this app installed on my phone and not getting this battery drain problem.
