chadwixk
Dec 20, 2019Aspirant
Bug - Quota Issues? Error: 1002030001
I am getting the Not Enough Free Space error (as referred to here), but do not have set quotas. The disk has 875GB free. The share properties shows the quota section blank.
Is there a default or implied quota if none is explicitly set? When I try to set an explicit quota amount, like 400GB, I get this error:
Model: ReadyNAS 102
Firmware: 6.10.2
Context: shares_panel_volume
Error:
1002030001
Commit failed
Sort By
Is quota enabled on the volume (check the volume settings wheel on the volume tab)?
Any errors related to the free space in the root?
- chadwixkAspirant
Thanks for pointing that settings section out, I never stumbled across it before.
Yes, the Quota checkbox is checked. Unfortunately, trying to uncheck and apply gives an error:
Model: ReadyNAS 102
Firmware: 6.10.2
Context: system_wnd_prop_volume
Error:
1014019994
Can you download the log zip file?
