ginak
Apr 04, 2016Aspirant
Cannot access local admin page and not allowing authorization
Having trouble logging into local admin page after having readycloud discover ReadyNas device. When the new window opens to the local admin page authorization, I've tried admin/password and a slew of...
- Apr 05, 2016
Pages 16-17 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN_OS_6_Desktop_HW_UM_12Oct2015.pdf
ginak
Apr 05, 2016Aspirant
Thanks for the help!
Model is RN10200 (Diskless). Just updated ReadyCloud to most up to date (v.1.8.1220 and then did another update after install).
Readycloud remote access was working this fall during my travels, but then stopped working this spring and the only change (that I'm aware of) is the new Netgear N750 router (and associated modem provided by ISP - Thomson ST 516 Speedtouch v6).
Thanks!
BrianL2
Apr 05, 2016NETGEAR Employee Retired
Hi ginak,
Thanks for your feedback. It is possible that the IP address has been changed or had a conflict after installing the new router in your network. Could you try to check or track the IP address of your ReadyNAS using the RAIDar utility? Also, try to access the local device admin page via http or https (eg. http://192.168.1.1 or https://192.168.1.1). If this won't work, last thing you could try is to perform an OS Reinstall (will only reset the admin password and network settings).
Kind regards,
BrianL
NETGEAR Community Team
- ginakApr 05, 2016Aspirant
Brian,
Used RAIDer and found the IP address and entered it as http://XXXXXXXX and it takes me to the username/password authorization request, similar to if I try to "manage" the ReadyNas 102 thru Readycloud (same IP address). I fail the username/password since I don't know what it is and admin/password aren't working.
Then I also fail the password recovery after "canceling" the username/password, though I'm pretty sure I'm using the right email/recovery answer combo...
Thoughts next?
I mean, its working locally when I'm attached to the router, just can't get it to connect via ReadyCloud remotely...
- BrianL2Apr 05, 2016NETGEAR Employee Retired
Hi ginak,
Try the suggestions I gave when you are on your local network. We need to check the Cloud settings of your system as well as the ReadyCLOUD admin account linked to it (still on your local network).
Kind regards,
BrianL
NETGEAR Community Team- ginakApr 05, 2016Aspirant
On local network the desktop ReadyCloud (v1.9) is showing ReadyNas 102 is offline and won't connect.
Though I am connected to it and can view it thru RAIDer... If I try to access "Setup" thru RAIDer it takes me to the IP address that I don't have log-in credentials for...
Sorry if I'm not understanding what you are asking. Treat me like a dolt, I'm ok with that...
