ginak
Apr 04, 2016Aspirant
Cannot access local admin page and not allowing authorization
Having trouble logging into local admin page after having readycloud discover ReadyNas device. When the new window opens to the local admin page authorization, I've tried admin/password and a slew of...
- Apr 05, 2016
Pages 16-17 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN_OS_6_Desktop_HW_UM_12Oct2015.pdf
ginak
Apr 05, 2016Aspirant
I'm out of UN/PW combinations and find it odd that the PW reset is also not working. So I think Os Reinstall is best solution. Can you provide instructions and/or link for this?
Thank you!
Apr 05, 2016Guru - Experienced User
- ginakApr 05, 2016Aspirant
Good to go after OS reinstall!
Thank you Brian & Stephen!
- BrianL2Apr 05, 2016NETGEAR Employee Retired
Hi ginak,
We're glad that we've been a help to you. Just update this thread or make a new one if you have other questions.
Kind regards,
BrianL
NETGEAR Community Team - ginakApr 06, 2016Aspirant
Two problems have arisen in the 24 hours since everything was working correctly...
Readycloud is again showing the ReadyNas 102 as offline and it is operating very slowly on the local connection.
Firmware is 6.4.2
Chrome up to date, Windows 7.
Thank you.
I've disabled the anti-virus for 6.4.2 and that appears to have improved the speed.
Still having it appear as offline in ReadyCloud though in "Manage" under "cloud" tab both internet available and service available are green checks....
- BrianL2Apr 06, 2016NETGEAR Employee Retired
Hi ginak,
Can you confirm if the same behavior shows if you will access ReadyCLOUD via the web portal and desktop /or mobile apps? If yes, log out and log in your admin account under the cloud tab then let us know if you're still experiencing issues after doing this.
Kind regards,
BrianL
