ylafont
Feb 08, 2018Aspirant
Cannot connect to ReadyCloud
I think i have tried everything and cannot connect to ReadyCloud,
Changed DNS to 8.8.8.8
Disable IP 6
made sure UPnP is enable
All APPS appeare in Cloud tab, Amazon, goodle Drive, Az...
JohnCM_S
Feb 08, 2018NETGEAR Employee Retired
Hi ylafont,
Please try disabling the antivirus on the NAS and check if you will be able to join the NAS to Readycloud. If it is still the same, please download the system logs of the NAS and then do an OS re-install.
JohnCM_S
NETGEAR Community Team
- ylafontFeb 08, 2018Aspirant
Anti-Virus is not enabled on the NAS, this is also fresh install of the OS, and Firmware(6.9.2).
Out of nowhere the NAS reported ERR: No drives available on boot up a few days ago, which i cannot comprehend. After swapping drives back and forth, removing the MBR from the drives and updating the firmware. I have manage to get it back up and running. These are all new 6TB drives (WD reds). The cost is however, all data lost. luckily - this is a back up NAS! Now the scary thing is on reboot, it happen again. (hoping and praying it is stable now)
Logs are here
Thank you for the assistance.
New logs link
- JohnCM_SFeb 08, 2018NETGEAR Employee Retired
Hi ylafont,
Thank you for providing the logs. Please do not post your logs publicly. You may just PM the logs next time. I have remove the download link.
We will review first the logs and provide you a feedback once we are done.
JohnCM_S
NETGEAR Community Team- LoskidFeb 08, 2018Aspirant
I am not able to log in either. Goes to site ok but just keeps loading and doesn't change. I think it is down.
- ylafont2Feb 26, 2018Aspirant
Has there been any movement on this?
- mdgm-ntgrFeb 26, 2018NETGEAR Employee Retired
ylafont2 the ReadyCLOUD problem you're having would be due to your serial number being shown as the 12-digit MAC address of eth0 rather than the 13-digit NETGEAR serial number. This problem affected a batch of ReadyNAS Pro units and is easily fixed.
As for the other problem your logs show that you have two disks installed. Disk 2 has a spin retry count of 65537. Either this disk is failing badly or there's a hardware issue with the chassis (e.g. a failing PSU not providing enough power to spin up both disks reliably).
