ylafont
Feb 08, 2018Aspirant
Cannot connect to ReadyCloud
I think i have tried everything and cannot connect to ReadyCloud,
Changed DNS to 8.8.8.8
Disable IP 6
made sure UPnP is enable
All APPS appeare in Cloud tab, Amazon, goodle Drive, Az...
JohnCM_S
Feb 08, 2018NETGEAR Employee Retired
Hi ylafont,
Thank you for providing the logs. Please do not post your logs publicly. You may just PM the logs next time. I have remove the download link.
We will review first the logs and provide you a feedback once we are done.
JohnCM_S
NETGEAR Community Team
ylafont2
Feb 26, 2018Aspirant
Has there been any movement on this?
- mdgm-ntgrFeb 26, 2018NETGEAR Employee Retired
ylafont2 the ReadyCLOUD problem you're having would be due to your serial number being shown as the 12-digit MAC address of eth0 rather than the 13-digit NETGEAR serial number. This problem affected a batch of ReadyNAS Pro units and is easily fixed.
As for the other problem your logs show that you have two disks installed. Disk 2 has a spin retry count of 65537. Either this disk is failing badly or there's a hardware issue with the chassis (e.g. a failing PSU not providing enough power to spin up both disks reliably).
