nige_b
Jul 14, 2013Aspirant
Cannot reset ReadyCloud password
Hi,
I have just got the ReadyNAS RN102 and installation using the ReadyCloud option worked fine.
Later in the day I tried to log in using my ReadyCloud account but I could not log in.
I have used the password recovery option but the link just sends me back to the Netgear ReadyCloud page? I can't see anywhere where I can reset my password.
How do I reset my password please?
One other thing, when you have successfully discovered the NAS Device (as I have) if you run the discover option later should it find it again (mine doesn't)?
Thanks.
- vandermerweMasterHave you used:
https://www.readycloud.com/accounts/password/reset/
Try clearing your browser cache or using a different browser ( eg chrome )
I have the same problem with readycloud "losing" the device even though it is accessible via RAIDAR. I have an open support case about this and other issues. I would suggest you open a support case as well - even if you regain access. Netgear need to fix this. The more of us who report the problem the more important it should become for them to take the problem seriously. They keep telling me to try a different browser, when really they should be making their software compatible with existing browsers. - nige_bAspirantJust tried the password reset link but it says the e-mail account does not have an associated user which I know it does ...
Different browser did not fix the issue.
I guess I will have to log a call with support.
Thanks. - vandermerweMasterI assume you setup a readycloud account when you started setting up, it's possible to setup the NAS without setting up a readycloud account.
- nige_bAspirantYes I already have an account. I realise I can set the device us without this but I want to get it working.
No response from [email protected] ...
Still don't understand how I'm supposed to reset my password!
Thanks - vandermerweMasterHave you registered your readynas?
You should be registered here, and log a support request here, or find the phone number and give them a call.
https://my.netgear.com/registration/login.aspx - nige_bAspirantThanks I have done that.
Just can't believe how difficult it is to reset a password :( - vandermerweMasterThere are other tasks that should be simple that OS 6 and its fellow Readycloud seem to make surprisingly difficult.
- nige_bAspirantSupport told me to mail [email protected] which I did 3 days ago but still no reply :x
I think the NAS will be going back tomorrow for a refund. - vandermerweMasterVery sensible
Edit : Netgear , pay attention! - cap1AspirantYou can reset your password from ReadyCLOUD. If you visit http://readycloud.netgear.com and then click sign-in in the upper right corner you will see a dialog appear. At the bottom there is a link "Forgot Account" and clicking that link will begin the reset process.
