powellandy1
Nov 15, 2015Virtuoso
Cannot turn ReadyCLOUD on (Pro Pioneer)
Hi I have a Pro Pioneer upgraded to OS6. On 6.2.4 ReadyCLOUD worked completely fine. I've just upgraded to the latest 6.4.1 beta 3 and I cannot get ReadyCLOUD to toggle to on. I have tried leavi...
- Nov 21, 2015
Just as followup....
Skywalker kindly remotely accessed my Pro Pioneer and inputted the correct serial.
It is apparently something that affected very early Pro Pioneers - the serial wasn't correctly inputted in the factory.
It's all working fine now.
Kind regards,
Andy
powellandy1
I can confirm the problem is with 6.4.x
Downgraded to 6.2.4 via 6.4.0T112 and factory reset.
ReadyCLOUD works fine
Ensured leave readyCLOUD done thru GUI, deleted device from ReadyCLOUD itself and all remote settings off in GUI
Upgraded to 6.4.0 via GUI
ReadyCLOUD broken as above.
Please advise.
Thanks
Andy
JennC
Nov 19, 2015NETGEAR Employee Retired
Hello powellandy1,
New FW version will be released soon. We apologize for the inconvenience.
- powellandy1Nov 19, 2015Virtuoso
Awesome. Thanks for letting me know.
A
- powellandy1Nov 20, 2015Virtuoso
Hi
Exactly as before with RC1.
Logs emailed.
Readycloud.txt is filled with
Nov 20 17:02:10 Pro6 rcbrokerd[5246]: rxml.cpp:27 [rxml_getnodeset] error: node set is empty Nov 20 17:02:10 Pro6 rcbrokerd[5246]: rxml.cpp:55 [rxml_getvalue] error: failed getting nodes by path /registration/x_agent_id
Andy
- JennCNov 20, 2015NETGEAR Employee Retired
Hello powellandy1,
Try 6.4.1-RC1, according to another discussion it resolved ReadyCloud problems.
