powellandy1
Nov 15, 2015Virtuoso
Cannot turn ReadyCLOUD on (Pro Pioneer)
Hi I have a Pro Pioneer upgraded to OS6. On 6.2.4 ReadyCLOUD worked completely fine. I've just upgraded to the latest 6.4.1 beta 3 and I cannot get ReadyCLOUD to toggle to on. I have tried leavi...
- Nov 21, 2015
Just as followup....
Skywalker kindly remotely accessed my Pro Pioneer and inputted the correct serial.
It is apparently something that affected very early Pro Pioneers - the serial wasn't correctly inputted in the factory.
It's all working fine now.
Kind regards,
Andy
powellandy1
Nov 20, 2015Virtuoso
Its second hand, and interestingly worked fine in 6.2.4.
The serial number is correct I think, its just in lower case (which i've always thought is strange).
I've PM'd you pics of all the labels.
Many thanks for looking.
Kind regards,
Andy
powellandy1
Nov 21, 2015Virtuoso
Kind regards,
Andy
- powellandy1Nov 23, 2015Virtuoso
Just had a PM from mdgm - you can tell if this could effect you as very early Pro units the MAC address of the first ethernet port was the serial number rather than a typical NETGEAR serial number.
