Runejors
Oct 25, 2018Aspirant
cant access readynas duov2
When i am trying to access the unit i get this error ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I have tryed to reset the unit, without sucess. still no access
Well, the problem is an outdated https implementation and certificate on the legacy ReadyNAS - you can factory reset it thousand times, your modern browser will continue to nag about it. If possible create an exception (browser, Internet "security" garbage blocking, ... whatever), or (warning - funny advise) use http instead.
- RunejorsAspirant
Well, i have tried and still with the same result. No access.
When i try http instead, the adress automatic use https!? crap...
Crome dont accsept exeption to this adress
- Caleb570Aspirant
When I tried to use the mapped drives I was originally told that it couldn't open a connection because a connection already exists. Now it simply says the network connection was not found. Please help me.
That would be a completely different issue than the one on this thread. Please start a new one, and include the NAS model and the firmware version that is installed.
- BerhinAspirant
I have the same problem with my NAS. But when I turn off "Encrypted web scan" in my Bitdefender virusprotection, I can reach my NAS.
I have contacted Bitdefender, bit they say the problem lies with Netgear. I think that's true.
