jonjon1966
May 04, 2016Aspirant
Changes to ReadyNAS Remote following the migration to MyNETGEAR
Hi there I'm new to posting on community sites so not sure who will read, or might respond to this. I use readynas remote with my drive, with several different people accessing it using that syst...
May 04, 2016Guru - Experienced User
ReadyCloud also has a windows client that should let you access the NAS through file explorer.
Everyone you share with will need a mynetgear account (even if they don't own any netgear equipment). You of course will need to migrate everything to the new readycloud.
Alternatives you could consider are switching to owncloud or using bittorrent sync. Secure FTP is also an option (FileZilla has a pretty good drag/drop interface).
If you are ok with having the other users have full access to your home network, you could also use OpenVPN.
- jonjon1966May 04, 2016Aspirant
Thanks StephenB
Do you know if there is a link somewhere with information on how to use the windows client through ReadyCLOUD? I'm more tempted to work with that rather than introduce additional platforms, if it gives us what we need.
Cheers, Jon
- StephenBMay 04, 2016Guru - Experienced User
Probably the best way is to try the current readycloud - it shouldn't interfere with your ability to use remote.
Netgear hasn't said exactly what happens to remote - it is possible that all you'll need to do is switch to the new SSO log-ons. Hopefully they will clarify that here soon.
- JennCMay 04, 2016NETGEAR Employee Retired
Hello jonjon1966,
ReadyNAS Remote has been discontinued in FW 6.5.0, so if you want to still use it, then do not update to BETA 6.5.0 or the official 6.5.0 that is soon to be released. It should still work on 6.4.2 and earlier versions.
Welcome to the community!
