jonjon1966
May 04, 2016Aspirant
Changes to ReadyNAS Remote following the migration to MyNETGEAR
Hi there I'm new to posting on community sites so not sure who will read, or might respond to this. I use readynas remote with my drive, with several different people accessing it using that syst...
jonjon1966
Thanks StephenB
Do you know if there is a link somewhere with information on how to use the windows client through ReadyCLOUD? I'm more tempted to work with that rather than introduce additional platforms, if it gives us what we need.
Cheers, Jon
May 04, 2016Guru - Experienced User
Probably the best way is to try the current readycloud - it shouldn't interfere with your ability to use remote.
Netgear hasn't said exactly what happens to remote - it is possible that all you'll need to do is switch to the new SSO log-ons. Hopefully they will clarify that here soon.
- JennCMay 04, 2016NETGEAR Employee Retired
Hello jonjon1966,
ReadyNAS Remote has been discontinued in FW 6.5.0, so if you want to still use it, then do not update to BETA 6.5.0 or the official 6.5.0 that is soon to be released. It should still work on 6.4.2 and earlier versions.
Welcome to the community!
- JennCMay 07, 2016NETGEAR Employee Retired
Hello jonjon1966,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- mike_coreitSep 11, 2016Aspirant
Hi I have since upgraded to firmware 6.5.1 and the option for ReadyNAS Remote has disappeared from the Cloud management page.
I have already set-up a ReadyCLOUD account, but the login is not recognized in the ReadyNAS Remote client.
Edit: I have since discovered there is a ReadyCLOUD client which I have downloaded, and it is working now.
