JDB427
Dec 18, 2019Aspirant
Connecting a ReadyNAS RN422 to a backup RND2000 V1 both in separate locations
Hi, excuse the inoocent post, but I am quite new to this! I am looking to buy a ReadyNAS RN422 as a home network backup system. I have an older RND2000 V1 already. Could I install the RND2000 a...
Marc_V
Dec 18, 2019NETGEAR Employee Retired
Welcome to the Community!
Yes it is possible using rysncfor both NAS.
You may have to check the following links when enabling and setting up RSYNC
https://kb.netgear.com/20258/Using-Rsync-to-Backup-between-x86-ReadyNAS
https://kb.netgear.com/29788/ReadyNAS-Backup-FAQ
Please note that having backup on several storage aside from your NAS is always advise. Though the NAS helps you when there is failure, having multiple copies of backups will help you with your data redundancy.
HTH
Regards
- JDB427Dec 18, 2019Aspirant
Marc_V - many thanks - will study that, I presume that one system is older and running different generation operating software won't casue an issue? Thanks
- Marc_VDec 18, 2019NETGEAR Employee Retired
It should not cause an issue using rsync regardless of their OS. This might help as well https://kb.netgear.com/29730/How-do-I-back-up-data-from-a-RAIDiator-4-system-to-a-ReadyNAS-OS-6-system
Regards
- JDB427Dec 18, 2019AspirantMany thanks, off to read and research more!
