ramanj123's avatar
ramanj123
Could not connect to Readycloud
Hello,     I have a readynas 516. Current version is 6.9.3. I have Readycloud in switched off mode. If I try to switch on by sliding, it asks my email and login password, once I give, it says "Ther...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Aug 21, 2018
    Great! I had to remove a very old config file so the system could generate it again when you enabled ReadyCLOUD.
ProSupport for Business
