mrmpitts
Nov 17, 2017Aspirant
EXTERNAL DRIVE BACK UP - MAC Ready NAS
Hello, I run both mac and PC, and used to have folders on my external drives backing up to my ReadyNAS. For some reason, it stopped working, have attempted to set up new ones, but I can now no l...
Nov 20, 2017Guru - Experienced User
mrmpitts wrote:
I run both mac and PC, and used to have folders on my external drives backing up to my ReadyNAS. For some reason, it stopped working, have attempted to set up new ones, but I can now no longer find/select the external drives?
If you are using ReadyNAS backup jobs (and external drives connected to the PC), then the backup job is backing up a share, not the external drive itself (so you need to share the drive on the PC and Mac).
If this suddenly stopped working in 6.9.0, then you might want to check if the 6.9.0+4 hotfix is installed. Download the log zip file and look in apt-history.log. Toward the bottom you should see something like this:
Start-Date: 2017-11-06 04:48:07
Commandline: apt-get -qq install -fy rn-dictionary freeapp-collection readynasos ca-certificates
Upgrade: readynasos:amd64 (6.9.0+2, 6.9.0+4)
End-Date: 2017-11-06 04:48:10
If you don't see the upgrade to 6.9.0+4, then that likely is the issue. Try rebooting the NAS, and waiting about 15 minutes, and see if it arrives. Note the NAS must be set up to connect to the internet in order to receive the hotfix.
If 6.9.0+4 is there (or if you are running 6.8.1 or earlier), then your issue might be related to credentials. Try modifying the backup job to specify a user account on the PC that has access to the share- don't depend on guest.
A third possibility: Microsoft is deprecating SMB1, and many new windows 10 updates turn off the SMB server in the PC. So check to see if that has happened. If so, you can manually enable it, and see if that helps.
Personally, I don't use the built in backup jobs for PC backup (though I do use the built-in backup to back up the NAS itself) . I use tools in the PC which specify a NAS share as a target. I use Acronis TrueImage, but there are free tools that can also be used instead - for instance FreeFileSync (which runs on both OSX and Windows).
