SchneHa's avatar
SchneHa
How to add my two old ReadyNAS Duo to a MyNetgear Account?
Hello,
I own two old ReadyNAS Duo and backup pictures from my iPhone using an older version of ReadyCloud app and my ReadyCloud account. I didn't set up a MyNetgear account. That worked perfect under iOS 14.4.1. Now, iOS 14.5 is out and the older ReadyCloud app isn't supported anymore. Is there a possibility to change to a MyNetgear account and get the two old ReadyNAS with firmware 4.1.15 integrated?
Best regards,
Hans
  • Since the Duo does not support ReadyCloud, you have something confused.  The Duo did support ReadyNAS Remote, which has been offline for quite a while now, but I guess that's what you had.
    Your only real solution, other than purchasing a more up-to-date NAS, is a VPN, whihc would be best implemented via your router.  That only gives you access to the NAS, so you'll need to separately set up a solution for the backup/sync.
    • SchneHa's avatar
      SchneHa
      No, I'm speaking of ReadyCloud App on iOS which is called RCloud. It gives me the possibility to backup pictures on my iPhone to my NAS. I'm using RCloud V1.5.6 actual is V2.0.7
      • Sandshark's avatar
        Sandshark
        Sensei
        The ReadyNAS Duo (V1, which you have, and V2 as well) do not now nor have they ever supported ReadyCloud.  ReadyCloud is only available on ReadyNAS running OS 6, which your NAS cannot do.
ProSupport for Business
