pzh20
Aug 12, 2016Star
How to move the ReadyCloud folder
I have set up Readycloud, but the ReadyCloud folder is placed on my C: drive and I want it on my D: drive, how to do I change its location?
Regards
Pete
Hi pzh20,
No. It cannot be moved at the moment. I will give Kudos to the suggestion that you posted.
Kind regards,
BrianL
NETGEAR Community Team
- BrianL2NETGEAR Employee Retired
Hi pzh20,
Welcome to the community!
The default installation (ReadyCLOUD) folder is always placed in C: drive. I suggest that you post a new thread on this board that will allow users to set or change the directory of the ReadyCLOUD folder.
Kind regards,BrianL
NETGEAR Community TeamAre you suggesting that it cannot be moved?
I have sent an Idea to the forum you suggested.
Regards
Pete
Hi pzh20,
Kind regards,
BrianL
