hans7321's avatar
hans7321
HP spectre 4k screen problems
There must be a fault in the software, normaly I have my pc icon topmostleft on the screen and with the readycloud software running (auto-startup) my mouse pointer does not work on the upper left corner of my screen If I exit the program, it works normal ans as soon as readycloud 6.4.2 is turned on the fault repeats itself. If I hover over the third item from the top left, the first item is selected.
At the moment I have put 3 dummy folders on the top row of my screen to bypass the problem but that's not how it is supposed to be I think
    • hans7321's avatar
      hans7321
      Cannot make a snapshot with the mouse pointer active . The problem is : if I have ready cloud running in the background, and if I hover the mouse over “empty3”,than [empty1] is highlighted and when I right click on it, it says copy here, move here, create Shortcuts here and cancel.
      And if I exit the Ready cloud program, it behaves normally  The I can open [empty1] if I hover over [empty1] and [empty2] etc.
      Normally I have the pc icon on the place of [empty1] And if I don’t use ready cloud no problems. None what so ever than everything behaves normal. It took  a while to figure out that ready cloud was to blame for the fault.
      And about the resolution, it is set to recommended 3840x2160
      I have updated the firmware already at HP, but the problem is still here.
      As it is, I can work around it by keeping these three empty folders on my screen
      My laptop is a HP Spectre x360 15 inch
      Kind regards and thank very much for the rapid reaction.
      sorry, no idea how to add a picture at all at forums in general. Oh found it screenwithoutreadycloud.png
      • StephenB's avatar
        And what is the DPI scaling being used with the laptop?
ProSupport for Business
