s4mb4
Apr 29, 2013Aspirant
i feel like a BETA tester - OS 6
Hello Netgear, I am the owner of a ReadyNAS 516. I am also the owner of a Pioneer NVX and a Pro Business. I wanted the RN-516 because i wanted ReadyCloud. the thought of accessing my files and bei...
s4mb4
chirpa wrote: How many shares to you have DLNA enabled for? Can you try just one share with limited amount of files in it? There have been reports on the 4.2 platform of DLNA puking on some file formats, you may be seeing the same, where it crashes when it hits an odd file.
s4mb4 wrote: 1. ReadyDLNA does NOT work. WD TV Live, XBOX, Sony Bravia TV, IOS Plug Player, etc.... It DOES NOT work.
i have tested in with 1 file and as many as 30k. Its not that it does not stream or list, it does not even broadcast itself. To any device.Plex works fine on other platforms and stand alone distributions. It is more likely growing pains with the new addon SDK in 6.0. NTGR also bundles in Plex to the firmware, so Plex can't be as flexible as a stand alone add-on to provide quick updates; viewtopic.php?p=393007#p393007.
s4mb4 wrote: Plex, How hard is it to make your software work on Debian Wheezy.... must be near impossbile since it doesn't currently.
this is can accept.Same as above on Plex. SP's addon works fine on 4.1/4.2/5.3, it is likely the same SDK pains in 6.0 causing this issue. NTGR changed a lot in the new SDK and are not communicating clearly on the outstanding issues. It is not just Transmission, other add-ons like htop,Subsonic also have this issue where Genie uninstalls them each reboot. You can see issues reported by SP even in this thread: viewtopic.php?p=390451#p390451
s4mb4 wrote: Super Poussin, you should be ashamed of yourself for accepting $4.99 for Transmission that cannot survive a reboot.
this i CANNOT accept. if there are known issues, they SHOULD NOT appear in the Genie store. maybe i will create some apps and charge for them and when they do not work, just say, "O well, new SDK. I will work on it later"
