dyoung
Dec 08, 2017Tutor
iOS 11.x compatible with ReadyCLOUD app
I recently set up my ReadyNAS 212 on my home network and am able to access it via ReadyCLOUD in a web browser. Unfortunately I am not able to access it via the ReadyCLOUD app on either my iPhone or m...
klausn
Dec 19, 2017Tutor
Please remove the app from your phone and reinstall it.
- dyoungDec 19, 2017Tutor
klausn wrote:Please remove the app from your phone and reinstall it.
Unfortunately, no luck connnecting. Getting the same results. I even took it a few steps further by uninstalling the app, closing all other apps, turning off and restarting my phone before reinstalling the app from the app store.
Thanks,
- dyoungDec 27, 2017Tutor
UPDATE
A temporary solution was found with the help of Netgear Tech Support. Turns out there is an apparent bug that would not allow special characters in the password using the iOS version of the ReadyCloud app. At their suggestion I changed my password removing any special characters and was able to log in and access my NAS using the ReadyCloud app on my iPhone.
Hopefully this helps anyone else with this problem until they release a fixed iOS version of the app.
Don
- marco_hormesFeb 04, 2018Aspirant
Had the same issue with my ipHone 6s and was already looking for a solution for a while.
Changing my password and leaving the special characters out was the solution for me as well.
Thanks!!
Marco
